メインコンテンツにスキップ
HP Pavilion dv6-6117dx WiFi Adapter Replacement
必要な工具と部品
  1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: 手順 1、 2の画像 1 HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: 手順 1、 2の画像 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 2、 2の画像 1 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 2、 2の画像 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 3、 3の画像 1 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 3、 3の画像 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 3、 3の画像 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 4、 3の画像 1 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 4、 3の画像 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 4、 3の画像 3
    • Using a spudger, remove the white and black antenna wires from the WiFi Adapter
    • When connecting these wires later, line up the connector and press straight down until you feel them snap in place.
  5. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 5、 3の画像 1 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 5、 3の画像 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 5、 3の画像 3
    • Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
    • After the screws are removed the WiFi Adapter will raise to a 45º angle.
  6. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 6、 2の画像 1 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 手順 6、 2の画像 2
    • Always handle the WiFi Adapter by the edges to avoid damaging the part.
    • Pull the WiFi Adapter out of the slot at a 45º angle.
    • When inserting the new WiFi Adapter, you should insert it at this same angle.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Joshua Holme
メンバー登録日: 03/19/18
765 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018人のメンバー
UMASSD-BERNIER-S18S6G3
3 メンバー
4のガイドは作成済み
コメント 1 件
Thanks i need to replace the wifi adapter in an old pc of mine,looks pretty simple.
pturner14 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 2,284
