はじめに
Is your computer out of storage? Maybe you want to make your computer faster. Replacing the hard drive with a Solid State Drive (SSD) will help make your computer run faster, while also giving you more storage if you get a larger one. This guide will walk you through replacing your hard drive with another hard drive or SSD. Grab a spudger, a Phillips #0 screw driver and a clean work space, then follow the steps below.
必要な工具と部品
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
4 の人々がこのガイドを完成させました。
