メインコンテンツにスキップ
HP Pavilion dv6-6117dx Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 2、 2の画像 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 3、 3の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 3、 3の画像 2 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 3、 3の画像 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 4、 3の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 4、 3の画像 2 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 4、 3の画像 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 5、 3の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 5、 3の画像 2 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 5、 3の画像 3
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 6、 2の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 6、 2の画像 2
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 7、 3の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 7、 3の画像 2 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 7、 3の画像 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 8、 2の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 8、 2の画像 2
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 9、 2の画像 1 HP Pavilion dv6-6117dx Hard Drive Replacement: 手順 9、 2の画像 2
    • Remove the SATA cable from the hard drive.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Joshua Holme
メンバー登録日: 03/19/18
765 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018人のメンバー
UMASSD-BERNIER-S18S6G3
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 11
過去 30 日: 44
今までの合計 2,536
