メインコンテンツにスキップ
HP Pavilion dv6-1245dx TouchPad Button Replacement
必要な工具と部品
  1. HP Pavilion dv6-1245dx TouchPad Button Replacement, TouchPad Button: 手順 1、 1の画像 1
    • Shut down the computer and unplug it from the outlet.
    • Disconnect the power supply cord from the side of the laptop.
  2. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 2、 1の画像 1
    • Remove the battery by sliding and holding the battery release latch to the left.
    • While holding the release, lift the battery away from the battery bay and set aside.
  3. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 3、 1の画像 1
    • Remove four screws from the battery bay, using the Phillips #00 screwdriver.
    • The screws are 4 mm long and the heads are 4 mm wide.
    • All screw removal/loosening in this guide will require a Phillips #00 screwdriver.
  4. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 4、 1の画像 1
    • Starting with the four corners of the laptop, remove all remaining screws from the computer. There will be ten total screws to remove.
    • All ten screws are 7 mm long and the heads are 4 mm wide.
  5. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 5、 1の画像 1
    • Loosen the screws from the hard drive bay cover.
    • The screws will not come out all the way.
    • Remove the hard drive bay cover and set aside.
  6. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 6、 1の画像 1
    • Remove the hard drive by using the Mylar tab and lifting gently, as it is still connected to the system board by the hard drive cable.
    • Be sure that the computer is turned off and unplugged before removing the hard drive.
    • Discharge yourself of static electricity before handling the hard drive.
  7. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 7、 1の画像 1
    • Disconnect the hard drive from the hard drive cable by pulling them apart at the connector. The cable can be difficult to loosen, so while being gentle, you will have to pull hard to disconnect the hard drive.
    • After removing the hard drive, do not touch the connector.
  8. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 8、 1の画像 1
    • Loosen the screws from the memory module compartment cover.
    • Remove the memory module compartment cover and set aside.
  9. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 9、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 9、 2の画像 2
    • Remove the two memory modules by spreading apart the two silver retaining tabs, using your thumb and index finger. Pull and lift the green memory module upward at a 45-degree angle, then pull the memory module out of the computer.
    • Repeat for the second memory module located directly underneath the first.
  10. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 10、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 10、 2の画像 2
    • Disconnect both the black and white (or grey) WLAN antenna cables attached to the WLAN module by lifting gently at the gold base.
    • The cables have stickers labeled "1" and "2". These cables attach to the "J1" and "J2" on the WLAN module.
  11. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 11、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 11、 2の画像 2
    • Remove the single silver screw from the WLAN module, and pull the module away from the slot at a 45-degree angle.
    • The screw is 4 mm long and the head is 4 mm wide.
  12. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 12、 1の画像 1
    • Remove the hard drive connector from the system board by lifting the Mylar tab.
  13. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 13、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 13、 2の画像 2
    • Remove the screw that secures the optical drive to the computer.
    • The screw must be fully removed for the optical drive to be properly removed.
    • The screw is 7 mm long and the head is 4 mm wide.
  14. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 14、 1の画像 1
    • Insert a paperclip into the disk tray release access hole of the optical drive. The disk tray will eject automatically when the paperclip reaches the release.
    • Before removing the optical drive, be sure that a disc is not in the drive. Like all drives, optical drives are fragile, so handle with care.
    • Several attempts may be necessary to reach the disk tray release access hole, as it is located pretty far back within the optical drive.
  15. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 15、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 15、 2の画像 2
    • Remove the 4 screws marked with keyboard symbols. One is located to the left of the memory module, two are in the hard drive bay, and one is in the battery bay.
    • The screws are 7 mm long and the heads are 4 mm wide.
  16. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 16、 1の画像 1
    • Flip over the computer so that the keyboard is facing you.
  17. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 17、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 17、 2の画像 2
    • Using the plastic opening tool, loosen the switch cover by inserting the tool under the cover and gently pulling up until the switch cover releases. Begin at the top right-hand corner of the keyboard.
    • The switch cover will remain connected to the system board.
  18. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 18、 1の画像 1
    • While holding the switch cover up, remove the 3 silver screws underneath that connect the keyboard to the computer.
  19. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 19、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 19、 2の画像 2
    • Set the switch cover down, resting on the computer.
    • Lift the keyboard from the base. It will still be attached to the system board.
  20. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 20、 3の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 20、 3の画像 2 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 20、 3の画像 3
    • Tilt the bottom edge of keyboard up toward the display. Pull up the black tab to allow removal of the keyboard cable connector. Then pull the cable gently by holding the blue area to remove the cable entirely.
    • Place the keyboard and connector aside.
  21. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 21、 1の画像 1
    • Disconnect the LED board cable from the connector on the system board by pulling the blue Mylar tab in the direction of the display (away from you).
  22. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 22、 1の画像 1
    • Disconnect the power button board cable from the connector on the system board by pulling the blue Mylar tab toward the display (away from you).
    • Place the switch cover aside.
  23. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 23、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 23、 2の画像 2
    • In the upper left-hand corner of the laptop, disconnect the display panel cable by lifting the Mylar tab upwards toward the screen to release from the connector.
    • The display panel cable can remain connected to the system board.
  24. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 24、 3の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 24、 3の画像 2 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 24、 3の画像 3
    • Lift up the yellow tape attached to reveal the webcam/microphone cable. Release the cables from under the grey clip built in to the top cover by gently pushing them away with the spudger.
    • Use the flat end of the spudger to detach the silver webcam/microphone cable from the system board by pulling the white connector away from the system board.
  25. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 25、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 25、 2の画像 2
    • Disconnect the power connector cable by using the flat end of the spudger tool. Gently pry the cable until it completely disconnects, or you are able to grab the plastic piece, NOT the wires, to remove the cable.
    • This may be difficult. The pryer tool should touch only the plastic pieces.
  26. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 26、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 26、 2の画像 2
    • Disconnect the audio cable from the system board using the spudger tool.
  27. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 27、 1の画像 1
    • Disconnect the TouchPad cable from the system board by pulling the blue Mylar tab toward you.
  28. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 28、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 28、 2の画像 2
    • Support the display assembly while removing these next screws to avoid damage to the display screen.
    • Remove the 4 screws that fasten the display assembly to the computer. Carefully lift the display assembly off the computer and set aside.
  29. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 29、 1の画像 1
    • On the side of the computer farthest away from you, remove the 3 black screws from the top cover.
  30. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 30、 2の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 30、 2の画像 2
    • Turn the computer over so the bottom is facing up and the battery bay is facing away from you.
    • Remove the screw directly above the Intel card next to the TV symbol.
  31. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 31、 1の画像 1
  32. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 32、 3の画像 1 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 32、 3の画像 2 HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 32、 3の画像 3
    • Starting in the optical drive area, slide the plastic opening tool under the top cover, prying up each side to loosen it from the computer.
    • Remove the screw attaching the cover to the system board.
    • The screw is 4 mm long and the head is 5 mm wide.
    • If you are having a hard time removing the cover, turn the computer over to ensure you removed all screws as mentioned in previous steps.
  33. HP Pavilion dv6-1245dx TouchPad Button Replacement: 手順 33、 1の画像 1
    • Now that the top cover is removed, check for debris or food particles that may have become trapped underneath the top cover's TrackPad button area.
    • Optional: Use compressed air to clean out dust and debris.
    • If the TrackPad button is broken, you will need to replace the entire top cover piece purchase and install HP spare part number 518789-001.
終わりに
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jennifer
メンバー登録日: 01/23/14
580 ポイント
3のガイドは作成済み
チーム
New Mexico State, Team 1-3, Sheppard Spring 2014 New Mexico State, Team 1-3, Sheppard Spring 2014人のメンバー
NMSU-SHEPPARD-S14S1G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 29
今までの合計 20,494
