メインコンテンツにスキップ
HP Pavilion dv5000 Screen Lock Mechanism Replacement
必要な工具と部品
  1. HP Pavilion dv5000 Screen Lock Mechanism Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Screen Lock Mechanism Replacement, Screen Lock Mechanism: 手順 2、 1の画像 1
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment. (shown by the red circles)
    • Remove the three 6.0mm screws. (shown by the blue circles)
    • Remove the two silver 5.0mm screws. (shown by the yellow circles)
    • Remove the 6.0mm screw in the middle of the battery compartment. (shown by the teal circle)
  3. HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 3、 3の画像 1 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 3、 3の画像 2 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 3、 3の画像 3
    • Lift plastic covering strip gently at the corner to separate the plastic it from the keyboard area.
    • Slide a plastic separator tool along the strip and lift off to remove it.
  4. HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 4、 3の画像 1 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 4、 3の画像 2 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using tweezers, remove the (8) silicone covers over the screws of the screen's frame.
    • The image still shows the plastic strip that was removed in the last step
    • Remove the (8) now-exposed screws.
  5. HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 5、 3の画像 1 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 5、 3の画像 2 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 5、 3の画像 3
    • Using the plastic separator, make your way up from the bottom, separating the screen's frame off.
    • You may need to finagle the locking tab slightly in order to pull the frame away from it
  6. HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 6、 3の画像 1 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 6、 3の画像 2 HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 6、 3の画像 3
    • With frame removed, the locking assembly is visible
    • Using tweezers, pull the spring off the hook, and the locking assembly will pull down and off with little effort
    • Be sure not to drop the spring behind the screen while removing it!
  7. HP Pavilion dv5000 Screen Lock Mechanism Replacement: 手順 7、 1の画像 1
    • Congratulations! You're ready to install the new assembly and reassemble your laptop!
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Thomas Leman
メンバー登録日: 03/11/14
234 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 4-5, Calaway Spring 2014 UMass Dartmouth, Team 4-5, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S4G5
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 868
