メインコンテンツにスキップ
HP Pavilion dv5000 Power Supply Port Replacement
必要な工具と部品
  1. HP Pavilion dv5000 Power Supply Port Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Power Supply Port Replacement, RAM Cover: 手順 2、 3の画像 1 HP Pavilion dv5000 Power Supply Port Replacement, RAM Cover: 手順 2、 3の画像 2 HP Pavilion dv5000 Power Supply Port Replacement, RAM Cover: 手順 2、 3の画像 3
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 Power Supply Port Replacement, Wifi Card: 手順 3、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement, Wifi Card: 手順 3、 2の画像 2
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  4. HP Pavilion dv5000 Power Supply Port Replacement: 手順 4、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 4、 2の画像 2
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
  5. HP Pavilion dv5000 Power Supply Port Replacement, Hard Drive: 手順 5、 1の画像 1
    • Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
  6. HP Pavilion dv5000 Power Supply Port Replacement: 手順 6、 1の画像 1
    • Remove the two screws securing the hard drive cover.
  7. HP Pavilion dv5000 Power Supply Port Replacement: 手順 7、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 7、 2の画像 2
    • Remove the hard drive cover.
    • The hard drive is now accessible.
  8. HP Pavilion dv5000 Power Supply Port Replacement: 手順 8、 1の画像 1
    • Remove the two 5.0mm screws securing the hard drive bracket.
  9. HP Pavilion dv5000 Power Supply Port Replacement: 手順 9、 3の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 9、 3の画像 2 HP Pavilion dv5000 Power Supply Port Replacement: 手順 9、 3の画像 3
    • Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame.
    • Lift the hard drive out of the hard drive bay, left side first.
  10. HP Pavilion dv5000 Power Supply Port Replacement: 手順 10、 1の画像 1
    • Remove the hard drive.
    • If you are replacing the hard drive, remove the four additional screws (two on each side) securing the metal shield to the hard drive. Then, remove the shield from the drive.
  11. HP Pavilion dv5000 Power Supply Port Replacement, Optical Drive: 手順 11、 1の画像 1
    • Remove the 11.0mm screw securing the optical drive to the computer.
  12. HP Pavilion dv5000 Power Supply Port Replacement: 手順 12、 3の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 12、 3の画像 2 HP Pavilion dv5000 Power Supply Port Replacement: 手順 12、 3の画像 3
    • Locate the optical drive. The optical drive is located on the left side of the RAM bay.
    • Press the exposed edge of the optical drive gently with the spudger until the drive releases from the computer frame.
    • Pull the optical drive completely out of the computer frame.
  13. HP Pavilion dv5000 Power Supply Port Replacement, Keyboard: 手順 13、 1の画像 1
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  14. HP Pavilion dv5000 Power Supply Port Replacement: 手順 14、 1の画像 1
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  15. HP Pavilion dv5000 Power Supply Port Replacement: 手順 15、 1の画像 1
    • Be careful not to bend the keyboard switch cover too far when removing it.
  16. HP Pavilion dv5000 Power Supply Port Replacement: 手順 16、 1の画像 1
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  17. HP Pavilion dv5000 Power Supply Port Replacement: 手順 17、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 17、 2の画像 2
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  18. HP Pavilion dv5000 Power Supply Port Replacement: 手順 18、 1の画像 1
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  19. HP Pavilion dv5000 Power Supply Port Replacement: 手順 19、 1の画像 1
    • Lift the keyboard off the keyboard frame.
  20. HP Pavilion dv5000 Power Supply Port Replacement, Trackpad: 手順 20、 1の画像 1
    • Remove the two 3.0mm screws on the side of the laptop shown.
    • Remove the one 5.0mm screw in the hard drive compartment.
  21. HP Pavilion dv5000 Power Supply Port Replacement: 手順 21、 1の画像 1
    • Remove the eight 10mm screws securing the top cover to the laptop.
  22. HP Pavilion dv5000 Power Supply Port Replacement: 手順 22、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 22、 2の画像 2
    • Flip the computer over and disconnect the Touchpad Cable.
  23. HP Pavilion dv5000 Power Supply Port Replacement: 手順 23、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 23、 2の画像 2
    • Remove the silver 5.0mm screws Located in the silver area of the top cover
    • Remove the seven 10.0mm screws located on the top cover.
  24. HP Pavilion dv5000 Power Supply Port Replacement: 手順 24、 1の画像 1
    • Lift off the top cover and remove it. Lift off from the back.
  25. HP Pavilion dv5000 Power Supply Port Replacement: 手順 25、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement: 手順 25、 2の画像 2
    • Congratulations! You're ready to install the new assembly and reassemble your laptop!
  26. HP Pavilion dv5000 Power Supply Port Replacement, Power Supply Port: 手順 26、 2の画像 1 HP Pavilion dv5000 Power Supply Port Replacement, Power Supply Port: 手順 26、 2の画像 2
    • Locate the Power Supply Port
    • Lift the port up to remove it from its seated position
終わりに
作成者
2人の作成者と共同で作成されました。
Thomas Leman
メンバー登録日: 03/11/14
234 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 4-5, Calaway Spring 2014 UMass Dartmouth, Team 4-5, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S4G5
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 2,292
