メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will show you how to remove the keyboard, in case you need to replace it.
パーツ
パーツは指定されていません。
  1. Turn off and unplug the computer from all external power sources.
    • Turn off and unplug the computer from all external power sources.
    • Shut the screen, and lay the computer face-down on a flat, sturdy surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image. Sliding this switch from right to left will release the battery.
    • Remove the battery.
  2. Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  3. Turn the computer over and open the screen. This provides access to the screen hinges.
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  4. Be careful not to bend the keyboard switch cover too far when removing it.
    • Be careful not to bend the keyboard switch cover too far when removing it.
  5. Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  6. Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors. Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  7. This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  8. This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lift the keyboard off the keyboard frame.
終わりに
6 の人々がこのガイドを完成させました。
Alex Kwok
メンバー登録日: 2010年10月05日
268 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S21G34
4 メンバー
11のガイドは作成済み
2 件のコメント
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Arkadiusz Gąsior - 返信
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
stevefranklin75 - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 10,737
