この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The hard drive is the memory storage device located on the bottom of the laptop, directly below the track pad.
必要な工具と部品
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
To reinstall the hard drive and reassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
