はじめに
The hard drive is the memory storage device located on the bottom of the laptop, directly below the track pad.
ツール
パーツ
パーツは指定されていません。
Shut the screen, and lay the computer face-down on a flat, sturdy surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image. Sliding this switch from right to left will release the battery.
Remove the battery.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
To reinstall the hard drive and reassemble your device, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
