メインコンテンツにスキップ
HP Pavilion dv4000 CD/DVD drive Replacement
必要な工具と部品
  1. HP Pavilion dv4000 CD/DVD drive Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 CD/DVD drive Replacement: 手順 2、 1の画像 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 CD/DVD drive Replacement: 手順 3、 1の画像 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 CD/DVD drive Replacement, Hard Drive: 手順 4、 1の画像 1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 CD/DVD drive Replacement: 手順 5、 1の画像 1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 CD/DVD drive Replacement: 手順 6、 2の画像 1 HP Pavilion dv4000 CD/DVD drive Replacement: 手順 6、 2の画像 2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 CD/DVD drive Replacement: 手順 7、 1の画像 1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
  8. HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: 手順 8、 2の画像 1 HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: 手順 8、 2の画像 2
    • Locate the one 2x5 mm screw in the hard drive bay.
    • Unscrew the screw with a #00 Phillips screwdriver.
  9. HP Pavilion dv4000 CD/DVD drive Replacement: 手順 9、 3の画像 1 HP Pavilion dv4000 CD/DVD drive Replacement: 手順 9、 3の画像 2 HP Pavilion dv4000 CD/DVD drive Replacement: 手順 9、 3の画像 3
    • Locate the hole next to the DVD drive release button.
    • Insert a paperclip into the hole to release the DVD drive.
  10. HP Pavilion dv4000 CD/DVD drive Replacement: 手順 10、 2の画像 1 HP Pavilion dv4000 CD/DVD drive Replacement: 手順 10、 2の画像 2
    • Carefully grasp the DVD drive and slide it out.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick LaMarche
メンバー登録日: 10/18/16
373 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S4G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,128
