はじめに
After removing the battery you will remove the case cover on the back of your computer, then detach two wires connected to the wifi adapter/card, and finally remove the wifi adapter/card.
必要な工具と部品
Locate the two 7.5 mm screws on the hard drive case plate.
Use the Phillips #0 screw driver to remove both 7.5 mm screws.
2 の人々がこのガイドを完成させました。
コメント 1 件
Saving $$$ doing it myself, thanks this tutorial made it easy.... Thanks....
