メインコンテンツにスキップ
HP Pavilion dv4-2045dx Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion dv4-2045dx Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Turn off your laptop and disconnect the power adapter before doing anything else with your computer.
  2. HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 2、 1の画像 1
    • Turn your laptop over so the bottom of your laptop is facing up and the hinge is located away from you
  3. HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 3、 2の画像 1 HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 3、 2の画像 2
    • Slide the lock switch to the left.
    • The lock switch is located by the bottom left side of the battery.
    • The battery should pop up after you move the switch.
  4. HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 4、 3の画像 1 HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 4、 3の画像 2 HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 4、 3の画像 3
    • Lift up the released battery by rotating it up and away from you.
    • Pull the battery out.
    • The battery is held in by a latch in the front of the battery socket and by tabs in the back. When putting the battery back in, line the tabs back up with the grooves located in the back of the socket and rotate the battery towards you. When in place, push the battery in until you hear a click.
  5. HP Pavilion dv4-2045dx Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 1 HP Pavilion dv4-2045dx Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 2
    • Locate two 7.5 mm screws on the hard drive case plate.
    • Use the Phillips #0 screw driver to loosen both 7.5 mm screws.
    • These screws do not come out of the case plate; they only loosen and tighten.
    • Be sure to place the screws somewhere they will not roll away so that you do not lose them.
  6. HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 6、 1の画像 1
    • Remove the hard drive case plate.
    • You may use a thin object under the leftmost edge to pry open the case plate if you have trouble opening the hard drive socket.
  7. HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 7、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the 3 2.5 mm securing screws.
    • These screws are not the only screws located inside the hard drive/wi-fi card compartment, so be sure to only select the ones illustrated in the image.
  8. HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 8、 2の画像 1 HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 8、 2の画像 2
    • Slide the hard drive horizontally to the left.
    • The hard drive may be difficult to push. If so, use a rigid tool to push the hard drive.
  9. HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 9、 2の画像 1 HP Pavilion dv4-2045dx Hard Drive Replacement: 手順 9、 2の画像 2
    • Remove the hard drive from the socket
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Megan Todd
メンバー登録日: 09/22/15
600 ポイント
4のガイドは作成済み
チーム
Baylor, Team 6-8, Williams Fall 2015 Baylor, Team 6-8, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S6G8
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 3,742
