はじめに
If the hard drive on which your OS is installed fails, you will see a system error screen. If so, you will need to replace your main hard drive.
必要な工具と部品
Locate two 7.5 mm screws on the hard drive case plate.
Use the Phillips #0 screw driver to loosen both 7.5 mm screws.
もう少しです!
終わりに
4 の人々がこのガイドを完成させました。
