はじめに
The access only requires unplugging the power cable, the battery and removing a single compartment cover.
The type of memory is a DDR2 with SO-DIMM form factor, it has 2 slots, and it comes with 2GB each one from the factory, making a total of 4GB of memory.
According to the manufacturer, it admits up to 8GB of memory, however, 4GB DDR2 type DIMMs are very scarce and expensive; therefore I do not recommend them.
Although the factory modules have a frequency of 667mhz, the 800mhz modules should work, as the system must be able to lower their frequency to 667mhz.
必要な工具と部品
Verify the laptop model. Remove the power cable.
The battery only requires to move a latch to the left. With this, it comes out by itself.
Use a #0 phillips screwdriver to remove the RAM container cover.
Remove the hooks that hold the memories.
You can place new memories type DDR2, size SO-DIMM.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Pennyさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
