はじめに
This guide will help you replace the wireless card on you HP Pavilion dv2000.
必要な工具と部品
Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
Lift up and remove the wireless card casing.
この手順で使用する道具:Phillips #00 Screwdriver$5.49
Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
Gently pull out your wireless card from its top side to remove it from its holding.
3 の人々がこのガイドを完成させました。
