メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
HP Pavilion ZD7000 Fans Replacement
必要な工具と部品
  1. HP Pavilion ZD7000 Fans Replacement, Battery: 手順 1、 1の画像 1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Fans Replacement: 手順 2、 1の画像 1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Fans Replacement, Fans: 手順 3、 1の画像 1
    • Loosen the eight Phillips screws around the plate to remove it.
  4. HP Pavilion ZD7000 Fans Replacement: 手順 4、 1の画像 1
    • Remove the nine Phillips screws from the plate covering the fans.
    • The three screws around the lower fan also hold the fan onto the metal plate.
  5. HP Pavilion ZD7000 Fans Replacement: 手順 5、 1の画像 1
    • Lift the plate and lower fan off the heat sink being careful not to damage the lower fan cable, which is attached to the motherboard.
    • Disconnect the lower fan connector from the motherboard.
    • Remove the metal plate and lower fan.
    • The lower fan will easily separate from the metal plate.
  6. HP Pavilion ZD7000 Fans Replacement: 手順 6、 1の画像 1
    • Disconnect the upper fan connector from the motherboard.
    • Remove the four spring loaded screws holding the heat sink assembly to the motherboard.
    • When reassembling, ensure that all the screws are equally tightened: thread all screws one turn, then add one turn to each screw in the following order: top left, bottom right, bottom left, top right. Repeat this order until the assembly is firmly seated.
  7. HP Pavilion ZD7000 Fans Replacement: 手順 7、 1の画像 1
    • Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
    • When reinstalling the heat sink, ensure it is thoroughly cleaned and the thermal paste (or pads) are replaced to ensure proper thermal contact with the devices on the logic board.
終わりに
3 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Shantel
メンバー登録日: 04/20/10
545 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 30-37, Garner Spring 2010 Cal Poly, Team 30-37, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S30G37
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 6,561
