メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
はじめに
If your wi-fi keeps disconnecting or cannot connect at all even when other devices work properly, consider replacing your wireless card.
  1. Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. Using a spudger, pry the plastic plate off of the base of the computer.
    • Using a spudger, pry the plastic plate off of the base of the computer.
  3. Remove the screws from the WLAN card
    • Remove the screws from the WLAN card
  4. Remove the card by sliding out of the slot.
    • Remove the card by sliding out of the slot.
  5. Remove the cables from their connections by pulling them off. They should snap on and off.
    • Remove the cables from their connections by pulling them off. They should snap on and off.
終わりに
Nguyen
メンバー登録日: 2015年01月22日
289 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 21-22, Maness Winter 2015 Cal Poly, Team 21-22, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G22
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 277
