メインコンテンツにスキップ
HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 2、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 4、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 5、 2の画像 1 HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 6、 1の画像 1
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 7、 1の画像 1
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 手順 8、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
終わりに
作成者
3人の作成者と共同で作成されました。
Justin Hurley
メンバー登録日: 01/14/19
1 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S6-G6, Wilson Spring 2019 IUPUI, Team S6-G6, Wilson Spring 2019人のメンバー
IUPUI-WILSON-S19S6G6
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 24
今までの合計 384
