メインコンテンツにスキップ
HP Pavilion TPN-C125 RAM Replacement
必要な工具と部品
  1. HP Pavilion TPN-C125 RAM Replacement, RAM: 手順 1、 2の画像 1 HP Pavilion TPN-C125 RAM Replacement, RAM: 手順 1、 2の画像 2
    • Flip the laptop over so the bottom is facing up and the external battery is at the top.
  2. HP Pavilion TPN-C125 RAM Replacement: 手順 2、 2の画像 1 HP Pavilion TPN-C125 RAM Replacement: 手順 2、 2の画像 2
    • Use your thumbs to slide the battery locks towards the center and pop the battery out.
  3. HP Pavilion TPN-C125 RAM Replacement: 手順 3、 2の画像 1 HP Pavilion TPN-C125 RAM Replacement: 手順 3、 2の画像 2
    • Slowly peel off the two rubber stoppers found at the top corners of the laptop.
    • This will expose two Philips #00 10 mm screws required to remove the back plate.
    • Be careful not to peel off the rubber stoppers too quickly as it could cause the adhesive on the rubber stopper to strip off.
  4. HP Pavilion TPN-C125 RAM Replacement: 手順 4、 2の画像 1 HP Pavilion TPN-C125 RAM Replacement: 手順 4、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the twelve 10 mm screws (from the twelve holes shown) that secure the bottom case.
    • Use an opening tool to carefully separate the back case from the chassis, working around all four sides.
    • You will hear a "click" as you release the clips and remove it.
  5. HP Pavilion TPN-C125 RAM Replacement: 手順 5、 3の画像 1 HP Pavilion TPN-C125 RAM Replacement: 手順 5、 3の画像 2 HP Pavilion TPN-C125 RAM Replacement: 手順 5、 3の画像 3
    • The RAM sticks can be found in the bottom right section of the laptop.
    • Push both side arms holding the RAM stick in place outwards.
    • The RAM sticks will "pop" up at a 45-degree angle when released from the arms.
    • Slide the RAM sticks out of the socket gently.
  6. HP Pavilion TPN-C125 RAM Replacement: 手順 6、 3の画像 1 HP Pavilion TPN-C125 RAM Replacement: 手順 6、 3の画像 2 HP Pavilion TPN-C125 RAM Replacement: 手順 6、 3の画像 3
    • Carefully slide the new replacement RAM sticks into their slots.
    • Make sure to align edge of the RAM sticks with the slots to avoid damaging both.
    • Gently push the RAM sticks downward until the latches click into place to secure them.
終わりに
作成者
2人の作成者と共同で作成されました。
Cesar Gomez
メンバー登録日: 03/05/24
183 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 7-10, Grodsky Spring 2024 CSU Los Angeles, Team 7-10, Grodsky Spring 2024人のメンバー
CSULA-GRODSKY-S24S7G10
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 71
今までの合計 171
