メインコンテンツにスキップ
HP Pavilion Sleekbook 15-b000 RAM replacement
必要な工具と部品
  1. HP Pavilion Sleekbook 15-b000 RAM replacement, Battery: 手順 1、 1の画像 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 2、 1の画像 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 3、 2の画像 1 HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 3、 2の画像 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 4、 1の画像 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 RAM replacement, Keyboard: 手順 5、 1の画像 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 6、 1の画像 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 7、 1の画像 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 8、 1の画像 1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 RAM replacement, Case: 手順 9、 1の画像 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 10、 1の画像 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 11、 1の画像 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 12、 3の画像 1 HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 12、 3の画像 2 HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 12、 3の画像 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 RAM replacement, Motherboard: 手順 13、 2の画像 1 HP Pavilion Sleekbook 15-b000 RAM replacement, Motherboard: 手順 13、 2の画像 2
    • Disconnect motherboard cable from left side USB and jacks
  14. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 14、 1の画像 1
    • Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the one 3.5mm Phillips #1 screw from the WiFi chip
  15. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 15、 1の画像 1
    • Remove motherboard.
  16. HP Pavilion Sleekbook 15-b000 RAM replacement, RAM: 手順 16、 1の画像 1
    • With the mother board removed flip it upside down.
  17. HP Pavilion Sleekbook 15-b000 RAM replacement: 手順 17、 1の画像 1
    • Pull the clips attaching the ram outwards.
    • Remove ram at a angle.
    • Do not force the RAM loose, this can break the RAM or motherboard
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sam Barkley
メンバー登録日: 02/13/18
983 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018人のメンバー
USFT-CHENG-S18S11G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 337
