メインコンテンツにスキップ
HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement
必要な工具と部品
  1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: 手順 1、 2の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: 手順 1、 2の画像 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 2、 2の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 2、 2の画像 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 3、 2の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 3、 2の画像 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Cooling Fan: 手順 4、 1の画像 1
    • Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected the wire.
  5. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 5、 3の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 5、 3の画像 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 5、 3の画像 3
    • Using a plastic opening tool, pry up along the edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
  6. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 6、 3の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 6、 3の画像 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 6、 3の画像 3
    • To disconnect the wire, pry up on the latch connecting it to the motherboard.
  7. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 7、 3の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 7、 3の画像 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 7、 3の画像 3
    • Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
    • Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far.
    • Do not completely pull the halves apart yet because there are still wires holding them together.
  8. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 8、 3の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 8、 3の画像 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 8、 3の画像 3
    • Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
  9. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 9、 2の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 9、 2の画像 2
    • Unscrew the circuit board underneath the power button.
    • Remove this circuit board by pulling up and away on the plastic tab.
  10. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 10、 3の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 10、 3の画像 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 10、 3の画像 3
    • Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
    • Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
  11. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 11、 2の画像 1 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 手順 11、 2の画像 2
    • Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
    • Using a plastic opening tool, remove the power cable for the fan.
    • Remove the fan from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Josh Svik
メンバー登録日: 04/10/18
281 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 397
