メインコンテンツにスキップ
はじめに
If your optical drive is not reading anything inserted, or is malfunctioning, it is possible that it is dirty or damaged due to electrical or physical circumstances. Once new optical drives are purchased, follow this guide to replace them.
パーツ
パーツは指定されていません。
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: 手順 1、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement, Keyboard: 手順 1、 2の画像 2
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Optical Drive Replacement: 手順 2、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement: 手順 2、 2の画像 2
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Optical Drive Replacement: 手順 3、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement: 手順 3、 2の画像 2
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: 手順 4、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: 手順 4、 2の画像 2
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  5. HP Pavilion N3350 Optical Drive Replacement: 手順 5、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement: 手順 5、 2の画像 2
    • Use a plastic opening tool to disconnect both cable connectors gently.
  6. HP Pavilion N3350 Optical Drive Replacement: 手順 6、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement: 手順 6、 2の画像 2
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  7. HP Pavilion N3350 Optical Drive Replacement: 手順 7、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement: 手順 7、 2の画像 2
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  8. HP Pavilion N3350 Optical Drive Replacement: 手順 8、 2の画像 1 HP Pavilion N3350 Optical Drive Replacement: 手順 8、 2の画像 2
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
終わりに
ある他の人がこのガイドを完成しました。
Lyndon Davis
メンバー登録日: 2018年03月19日
124 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018人のメンバー
UMASSD-PEAK-S18S3G8
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 146
