はじめに
If your optical drive is not reading anything inserted, or is malfunctioning, it is possible that it is dirty or damaged due to electrical or physical circumstances. Once new optical drives are purchased, follow this guide to replace them.
必要な工具と部品
Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
To remove this, pry it open with a spudger tool gently. It should pop out of place.
Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
Remove the top plastic covering from the base of the device.
ある他の人がこのガイドを完成しました。
