はじめに
Are you having trouble with missing keys? Or is your keyboard sticky from spilling liquid? Replacing a keyboard may solve the problem
必要な工具と部品
Slide the lock to remove the battery
After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
After the screws from battery house are removed, open the laptop to remove the keyboard frame.
Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
