メインコンテンツにスキップ
HP Pavilion G6-2249wm screen Replacement
必要な工具と部品
  1. HP Pavilion G6-2249wm screen Replacement, Battery removal: 手順 1、 1の画像 1
    • Make sure the computer is shut off.
    • When you know that is shut off you may remove the battery
  2. HP Pavilion G6-2249wm screen Replacement, Begin screen removal: 手順 2、 1の画像 1
    • Remove the little pieces of black sticky tape covering the screws that need to be removed in each lower corner
    needs*******
    wyatt - 返信
  3. HP Pavilion G6-2249wm screen Replacement, screw removal: 手順 3、 1の画像 1
    • After the little black sticky tape is removed the two little screws at the lower corners of the screen need to be removed (place the screws on a little piece of tape).
    is gone******
    wyatt - 返信
  4. HP Pavilion G6-2249wm screen Replacement, screen cover removal: 手順 4、 2の画像 1 HP Pavilion G6-2249wm screen Replacement, screen cover removal: 手順 4、 2の画像 2
    • After removing the screws, pop out the plastic protector (can be done with your fingers).
    • Start at one corner and run your finger under the plastic and it will pop out.
  5. HP Pavilion G6-2249wm screen Replacement, screen screw removal: 手順 5、 1の画像 1
    • On each side of the screen there are two little screws, one on top and one on bottom.
    • All four of the screws need to be removed (place the screws on a little piece of tape so they won't be lost).
  6. HP Pavilion G6-2249wm screen Replacement, screen removal: 手順 6、 1の画像 1
    • Once the screws are out, remove the screen and lay it on your keyboard.
  7. HP Pavilion G6-2249wm screen Replacement, digital attachment removal: 手順 7、 3の画像 1 HP Pavilion G6-2249wm screen Replacement, digital attachment removal: 手順 7、 3の画像 2 HP Pavilion G6-2249wm screen Replacement, digital attachment removal: 手順 7、 3の画像 3
    • Once the screen is laying down you will see a connector on the back of it.
    • Pull the sticker off which pulls the connector with it.
  8. HP Pavilion G6-2249wm screen Replacement, Reconnecting the screen: 手順 8、 1の画像 1
    • After the new screen has arrived, reconnect the little connecter strip.
  9. HP Pavilion G6-2249wm screen Replacement, Replacing the screws: 手順 9、 2の画像 1 HP Pavilion G6-2249wm screen Replacement, Replacing the screws: 手順 9、 2の画像 2
    • After the connecter has been connected place the screen back into its place.
    • Once the screen is in place put in the four little screws that go in each corner of the screen.
  10. HP Pavilion G6-2249wm screen Replacement, black cover placement: 手順 10、 2の画像 1 HP Pavilion G6-2249wm screen Replacement, black cover placement: 手順 10、 2の画像 2
    • After the screen is screwed in place the black plastic cover back over the screen.
    • Once the black over is in place start clicking the clips back into place by just pressing with your fingers.
  11. HP Pavilion G6-2249wm screen Replacement, Screwing the cover in place: 手順 11、 1の画像 1
    • After the black cover is in place start to but the two little screws back in the two button corners
  12. HP Pavilion G6-2249wm screen Replacement, Sticker placement: 手順 12、 1の画像 1
    • After the screws are in place the little black sticker over the screws.
  13. HP Pavilion G6-2249wm screen Replacement, Placing the battery: 手順 13、 1の画像 1
    • After the screen is in and everything is tight and in place you may but the battery back in.
  14. HP Pavilion G6-2249wm screen Replacement, Turning on the computer: 手順 14、 1の画像 1
    • Once the battery is in place you may turn is it on and watch your screen come back to life.
終わりに
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
hunter
メンバー登録日: 02/17/15
294 ポイント
1ガイドが承認済み
チーム
Vegas Room H9 Vegas Room H9人のメンバー
Community
13 メンバー
17のガイドは作成済み
コメント 1 件
Good guide. Easiest screen replacement ever.
I’m concerned about your poor little knuckles.
Jim Buchholz - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 10
今までの合計 4,144
