メインコンテンツにスキップ
HP Pavilion G6-1d16dx Motherboard Replacement
必要な工具と部品
  1. HP Pavilion G6-1d16dx Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 2、 1の画像 1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx Motherboard Replacement, Motherboard: 手順 4、 1の画像 1
    • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
    • The screws do not remove from the cover.
  5. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 5、 2の画像 1 HP Pavilion G6-1d16dx Motherboard Replacement: 手順 5、 2の画像 2
    • Unsnap the Cover by lifting the edge along the battery compartment.
    • Remove all of the body screws.
    • Remove the rubber cap and the screw underneath it.
  6. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 6、 3の画像 1 HP Pavilion G6-1d16dx Motherboard Replacement: 手順 6、 3の画像 2 HP Pavilion G6-1d16dx Motherboard Replacement: 手順 6、 3の画像 3
    • The keyboard is held in by nine tabs
    • Using a metal tool, depress the center tab and pry up the keyboard by pivoting the tool towards the screen.
  7. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 7、 2の画像 1 HP Pavilion G6-1d16dx Motherboard Replacement: 手順 7、 2の画像 2
    • Slide the tool that is now under the keyboard sideways along the edge and use another tool to depress the other tabs along the edge of the keyboard.
    • As you depress the tabs, the edges of the keyboard will pop up.
    • Lift off the keyboard
  8. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 8、 1の画像 1
    • Flip up the black tab holding the keyboard in place via the ribbon cable and pull out the cable
  9. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 9、 3の画像 1 HP Pavilion G6-1d16dx Motherboard Replacement: 手順 9、 3の画像 2 HP Pavilion G6-1d16dx Motherboard Replacement: 手順 9、 3の画像 3
    • Remove the two remaining ribbon cables.
    • Remove the screws holding in the protective cover underneath the keyboard.
    • Pop the cover off using any flat metal tool, starting with where you took out the optical drive
    • It will be very sticky near the edge closest to the screen. This is where the sticker in the battery compartment is stuck to. just use a little more force.
  10. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 10、 1の画像 1
    • Unplug the ribbon cable on the right side of the motherboard.
  11. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 11、 2の画像 1 HP Pavilion G6-1d16dx Motherboard Replacement: 手順 11、 2の画像 2
    • Underneath the computer, unscrew the hard drive connector screw, and pop out the hard drive plug-in.
  12. HP Pavilion G6-1d16dx Motherboard Replacement: 手順 12、 1の画像 1
    • Unscrew all mother board screws and lift the motherboard out of the body.
    • For replacing the screen hinges and screen, skip this step
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Calvin Kerr
メンバー登録日: 04/05/18
878 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 25
今までの合計 2,127
