はじめに
If your are experiencing problems with your device's Optical Drive consult this repair guide to restore your device to working order. Problems can include disks not loading, noisy disk drive, and scratching of inserted disks. To Start this guide all you need is a Phillip's head screwdriver.
必要な工具と部品
Turn the device over so that the bottom is facing upward.
Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
Remove this 6mm screw with a Philips #0 screwdriver.
ある他の人がこのガイドを完成しました。
