メインコンテンツにスキップ
HP Pavilion DV9700 Digital Media Control Panel Replacement
必要な工具と部品
  1. HP Pavilion DV9700 Digital Media Control Panel  Replacement, Digital Media Control Panel: 手順 1、 2の画像 1 HP Pavilion DV9700 Digital Media Control Panel  Replacement, Digital Media Control Panel: 手順 1、 2の画像 2
    • First turn the device so that the back is facing upward.
    • There is a tab located near the top left portion of the device.
    • Push the tab and pull the battery upward to remove the battery from the device.
  2. HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 2、 2の画像 1 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 2、 2の画像 2
    • In the battery compartment there are 6 4mm screws.
    • Unscrew these screws using a Philips #0 head screwdriver.
    • These screws are very small, make sure to have an organized place to put them.
  3. HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 3、 3の画像 1 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 3、 3の画像 2 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 3、 3の画像 3
    • Turn the laptop over to it's resting position.
    • Open the laptop and locate the media bar across the top of the keyboard.
    • On the left side of the media bar, insert a spudger under the media bar near the top.
    • Move the spudger toward the bottom of the media bar, releasing the clips.
  4. HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 4、 3の画像 1 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 4、 3の画像 2 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 4、 3の画像 3
    • On the right of the media bar insert the spudger near the top.
    • Move the spudger toward the bottom of the media to release the clips
  5. HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 5、 2の画像 1 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 5、 2の画像 2
    • Carefully pull the media bar upward about an inch.
    • Flip the media bar toward yourself to expose the cable still attached.
    • Make sure not to pull the media bar too far away from the device. This could cause damage to the cable or the cable port.
  6. HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 6、 3の画像 1 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 6、 3の画像 2 HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 6、 3の画像 3
    • The ribbon cable is located near the left side of the media bar.
    • The ribbon cable is held down by a brown clip.
    • Using a fingernail pry one of the sides of the clip to release it.
    • The clip is fragile, be careful not to use too much pressure.
  7. HP Pavilion DV9700 Digital Media Control Panel  Replacement: 手順 7、 1の画像 1
    • With the ribbon cable successfully detached you may now replace the media bar with a new, functioning one.
終わりに
作成者
2人の作成者と共同で作成されました。
Max Shangraw
メンバー登録日: 03/19/18
507 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 UMass Dartmouth, Team S6-G1, Bernier Spring 2018人のメンバー
UMASSD-BERNIER-S18S6G1
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 595
