メインコンテンツにスキップ
HP Pavilion DV5T-1000 Hard Drive Replacement
必要な工具と部品
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 2、 1の画像 1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 3、 2の画像 1 HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 3、 2の画像 2
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 4、 1の画像 1
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 5、 1の画像 1
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 6、 1の画像 1
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 7、 1の画像 1
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 8、 2の画像 1 HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 8、 2の画像 2
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 9、 2の画像 1 HP Pavilion DV5T-1000 Hard Drive Replacement: 手順 9、 2の画像 2
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Josh Taimanglo
メンバー登録日: 09/21/15
147 ポイント
1ガイドが承認済み
チーム
Colorado Springs, Team 6-5, Mcmichael Fall 2015 Colorado Springs, Team 6-5, Mcmichael Fall 2015人のメンバー
UCCS-MCMICHAEL-F15S6G5
4 メンバー
1のガイドは作成済み
コメント 1 件
Help after replacing hard drive installation of windows
Bettyjean Serrano - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 44
今までの合計 1,864
