Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
The yellow highlighted edge of the battery should pop up slightly when the switch is moved
Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
The screw will remain attached to the cover.
Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
Put the cover and screw to the.
This will reveal the hard drive.
With your fingers, grab the clear tab.
Pull right first, and then upwards (towards you).
The hard drive should slide out of place and detach from the laptop.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
