メインコンテンツにスキップ
HP Pavilion DV3 HP Pavilion Wireless Card Replacement
必要な工具と部品
  1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 2、 2の画像 1 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 2、 2の画像 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Wireless Card: 手順 3、 1の画像 1
    • With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
    • All three screws will have a 3.5 mm diameter head.
    • Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
    • One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
  4. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 4、 2の画像 1 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 4、 2の画像 2
    • Grab one of the edges to the cover and lift up (towards you).
    • Set the cover to the side.
    • The wireless card will now be exposed.
  5. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 5、 3の画像 1 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 5、 3の画像 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 5、 3の画像 3
    • Using your hand, pull the black and white antenna wires upwards.
    • This will disconnect the antenna wires from the card.
  6. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 6、 2の画像 1 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 6、 2の画像 2
    • Locate the two black screws connecting the wireless card to the laptop. They will have a 3.5 mm diameter head and be 4mm long. Remove the screws.
    • Once the screws are removed, the wireless card will pop up.
  7. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 7、 2の画像 1 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 手順 7、 2の画像 2
    • Grab the sides of the wireless card and pull it up and to the left to disconnect from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Brandon Baldovin
メンバー登録日: 09/30/13
548 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 14-10, Forte Fall 2013 Cal Poly, Team 14-10, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S14G10
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 1,638
