メインコンテンツにスキップ
HP Pavilion DV2160BR Inverter Replacement
必要な工具と部品
  1. HP Pavilion DV2160BR Inverter Replacement, Inverter: 手順 1、 1の画像 1
    • Start with the laptop sitting up and open.
  2. HP Pavilion DV2160BR Inverter Replacement: 手順 2、 3の画像 1 HP Pavilion DV2160BR Inverter Replacement: 手順 2、 3の画像 2 HP Pavilion DV2160BR Inverter Replacement: 手順 2、 3の画像 3
    • Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
    • Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
    • There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
    • There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
  3. HP Pavilion DV2160BR Inverter Replacement: 手順 3、 2の画像 1 HP Pavilion DV2160BR Inverter Replacement: 手順 3、 2の画像 2
    • Slide a plastic opener tool along the outside edges of the front screen panel, separating it from the screen. You may need to apply some firm pressure.
    • Once the panel is separated from the screen, gently pull it off and set it aside.
  4. HP Pavilion DV2160BR Inverter Replacement: 手順 4、 2の画像 1 HP Pavilion DV2160BR Inverter Replacement: 手順 4、 2の画像 2
    • The inverter is located underneath the screen.
    • Unscrew the two 5mm Phillips #0 screws holding it in place, one on each end of the inverter.
  5. HP Pavilion DV2160BR Inverter Replacement: 手順 5、 2の画像 1 HP Pavilion DV2160BR Inverter Replacement: 手順 5、 2の画像 2
    • Disconnect the grey LCD cable on the left side of the inverter by holding the inverter in place and pulling firmly on the connector.
    • Disconnect the backlight plug cable on the right side of the inverter by holding the inverter in place and pulling firmly on the connector.
  6. HP Pavilion DV2160BR Inverter Replacement: 手順 6、 1の画像 1
    • Remove the inverter from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Shannon
メンバー登録日: 04/11/13
55 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S13G66
3 メンバー
6のガイドは作成済み
コメント 1 件
Thank you for enriching my knowledge.
Hope to meet you again.
ashique mahamud - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 1,412
