はじめに
The inverter powers your laptop's screen, making it easy to see. If you're having issues with the visibility of your screen, like flickering, dimming, or even faint buzzing noises, the inverter could be faulty. Follow the steps in this guide to access your computer's inverter and replace or repair it.
必要な工具と部品
Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
3 の人々がこのガイドを完成させました。
