メインコンテンツにスキップ
HP Pavilion DV1000 Screen Replacement
必要な工具と部品
  1. HP Pavilion DV1000 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion DV1000 Screen Replacement: 手順 2、 1の画像 1
    • Flip the laptop over.
  3. HP Pavilion DV1000 Screen Replacement: 手順 3、 2の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 3、 2の画像 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion DV1000 Screen Replacement: 手順 4、 3の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 4、 3の画像 2 HP Pavilion DV1000 Screen Replacement: 手順 4、 3の画像 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion DV1000 Screen Replacement, Keyboard: 手順 5、 1の画像 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion DV1000 Screen Replacement: 手順 6、 2の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 6、 2の画像 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion DV1000 Screen Replacement, Media Keys: 手順 7、 1の画像 1
    • Turn the laptop upside-down again.
  8. HP Pavilion DV1000 Screen Replacement: 手順 8、 2の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 8、 2の画像 2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
  9. HP Pavilion DV1000 Screen Replacement, Screen: 手順 9、 1の画像 1
    • Remove the rubber inserts with the spudger.
    • Note: When reassembling, notice that the two lower rubber pieces are flatter than the four rubber pieces located at the top of the screen.
    • Remove the screws behind the rubber inserts.
  10. HP Pavilion DV1000 Screen Replacement: 手順 10、 2の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 10、 2の画像 2
    • Carefully pry loose the screen casing with a plastic prying tool.
  11. HP Pavilion DV1000 Screen Replacement: 手順 11、 2の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 11、 2の画像 2
    • Remove the plug by prying it loose with the spudger.
    • Pulling the plug with your fingers could be potentially dangerous unless you are wearing work gloves.
  12. HP Pavilion DV1000 Screen Replacement: 手順 12、 1の画像 1
    • Remove the single screw marked in the image.
    • Be careful not to break the clips or pull any wires.
  13. HP Pavilion DV1000 Screen Replacement: 手順 13、 3の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 13、 3の画像 2 HP Pavilion DV1000 Screen Replacement: 手順 13、 3の画像 3
    • Remove the 4 screws marked in the picture.
    • Support the back cover and set it down on the desk. Do not pull off the back cover.
  14. HP Pavilion DV1000 Screen Replacement: 手順 14、 2の画像 1 HP Pavilion DV1000 Screen Replacement: 手順 14、 2の画像 2
    • Remove the screws on each side of the screen. There are four screws on each side.
    • Remove the screen.
終わりに
3 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Tyler Latour
メンバー登録日: 03/12/14
266 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014人のメンバー
UMASSD-VIJAYBHASKAR-S14S6G7
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 3,420
