メインコンテンツにスキップ
HP Pavilion DM3-3010US Sound Card Replacement
必要な工具と部品
  1. HP Pavilion DM3-3010US Sound Card Replacement, Sound Card: 手順 1、 1の画像 1
    • Place the laptop upside down on a stable surface and locate the battery ejection switch.
  2. HP Pavilion DM3-3010US Sound Card Replacement: 手順 2、 1の画像 1
    • Eject the battery by sliding the switch sideways.
  3. HP Pavilion DM3-3010US Sound Card Replacement: 手順 3、 1の画像 1
    • Pull the battery outwards.
  4. HP Pavilion DM3-3010US Sound Card Replacement: 手順 4、 1の画像 1
    • Remove the 2 plastic panels covering the internals of the laptop.
    • The rectangular panel can be removed by sliding the latch.
    • The square panel is removable once the battery is removed.
  5. HP Pavilion DM3-3010US Sound Card Replacement: 手順 5、 1の画像 1
    • Removing the square panel reveals the location of the hard drive.
  6. HP Pavilion DM3-3010US Sound Card Replacement: 手順 6、 1の画像 1
    • Locate the two screws located on the side of the hard drive mounting hardware.
    • This is accessible from the back of the laptop, where the battery was located.
  7. HP Pavilion DM3-3010US Sound Card Replacement: 手順 7、 1の画像 1
    • Locate the 4 additional screws on the top of the mounting hardware for the hard drive.
    • Remove and set aside these screws.
  8. HP Pavilion DM3-3010US Sound Card Replacement: 手順 8、 1の画像 1
    • Pay attention to the SATA cable connecting the hard drive to the motherboard. It can be damaged if handled roughly.
    • Pull the SATA cable out of its receptacle and set the hard drive aside.
  9. HP Pavilion DM3-3010US Sound Card Replacement: 手順 9、 1の画像 1
    • The picture shows the HP Pavilion DM3-3000 Series Audio USB Card Reader Board w/Cable.
    • With the hard drive removed, open the laptop and set it down in the position for normal use.
    • Locate the seam between the top panel of the laptop and the frame.
    • The seam is on the left side of the laptop when the screen is facing you.
    • Pull the top cover, including keyboard, up from the left side of the laptop.
  10. HP Pavilion DM3-3010US Sound Card Replacement: 手順 10、 1の画像 1
    • Dismount the audio driver by removing the 4 highlighted screws.
    • The audio driver is located on the right side of the laptop while the screen is facing you.
  11. HP Pavilion DM3-3010US Sound Card Replacement: 手順 11、 1の画像 1
    • The audio driver and surrounding components are susceptible to damage if handled incorrectly.
    • Carefully pull the audio driver upwards, away from the motherboard.
    • The laptop is now ready to receive the replacement audio driver.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
michael mannen
メンバー登録日: 01/30/15
446 ポイント
3のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-7, Rountree Winter 2015 University of Kentucky Louisville, Team 1-7, Rountree Winter 2015人のメンバー
LOUISVILLE-ROUNTREE-W15S1G7
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 6
今までの合計 1,721
