メインコンテンツにスキップ
HP Pavilion 17-g192dx Screen Replacement
必要な工具と部品
  1. HP Pavilion 17-g192dx Screen Replacement, Battery: 手順 1、 3の画像 1 HP Pavilion 17-g192dx Screen Replacement, Battery: 手順 1、 3の画像 2 HP Pavilion 17-g192dx Screen Replacement, Battery: 手順 1、 3の画像 3
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Screen Replacement: 手順 2、 1の画像 1
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Screen Replacement: 手順 3、 2の画像 1 HP Pavilion 17-g192dx Screen Replacement: 手順 3、 2の画像 2
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Screen Replacement, Screen: 手順 4、 2の画像 1 HP Pavilion 17-g192dx Screen Replacement, Screen: 手順 4、 2の画像 2
    • Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
  5. HP Pavilion 17-g192dx Screen Replacement: 手順 5、 1の画像 1
    • Remove the two 7mm screws with a Philips #00 screwdriver.
  6. HP Pavilion 17-g192dx Screen Replacement: 手順 6、 3の画像 1 HP Pavilion 17-g192dx Screen Replacement: 手順 6、 3の画像 2 HP Pavilion 17-g192dx Screen Replacement: 手順 6、 3の画像 3
    • Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
    • It may be helpful to start with the metal spudger then transition to the plastic opening tool because you will need the metal tip get in initially.
  7. HP Pavilion 17-g192dx Screen Replacement: 手順 7、 3の画像 1 HP Pavilion 17-g192dx Screen Replacement: 手順 7、 3の画像 2 HP Pavilion 17-g192dx Screen Replacement: 手順 7、 3の画像 3
    • Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
    • Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
    • Lay the cover on the workspace carefully as not to damage the wires still connected to it.
  8. HP Pavilion 17-g192dx Screen Replacement: 手順 8、 1の画像 1
    • Unplug the wire connected to the display assembly by gently pulling on it.
    • Tape may be holding it in place.
  9. HP Pavilion 17-g192dx Screen Replacement: 手順 9、 2の画像 1 HP Pavilion 17-g192dx Screen Replacement: 手順 9、 2の画像 2
    • Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
    • It may be helpful to have someone else support the screen while you remove it.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dominic Perito
メンバー登録日: 09/20/19
616 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 348
