はじめに
The HP Pavilion 17-f127ds, is a standard “QWERTY” keyboard, if there is a malfunction or if you need to use a different language keyboard, you will need to remove the keyboard manually, this guide will assist you in the matter.
必要な工具と部品
Slide the battery lock latch, the latch on the left, inwards.
Slide the battery release latch on the right inwards to release the battery.
Lift the battery up and remove it from computer.
Flip your laptop over on a firm surface.
Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
Flip your laptop back over.
2 の人々がこのガイドを完成させました。
