メインコンテンツにスキップ
HP Pavilion 17-f004dx Screen Replacement
必要な工具と部品
  1. HP Pavilion 17-f004dx Screen Replacement, Battery: 手順 1、 1の画像 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Screen Replacement: 手順 2、 1の画像 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Screen Replacement, CD Drive: 手順 3、 1の画像 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Screen Replacement: 手順 4、 3の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 4、 3の画像 2 HP Pavilion 17-f004dx Screen Replacement: 手順 4、 3の画像 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Screen Replacement, Front Panel: 手順 5、 1の画像 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Screen Replacement: 手順 6、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 6、 2の画像 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Screen Replacement: 手順 7、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 7、 2の画像 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Screen Replacement: 手順 8、 1の画像 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Screen Replacement: 手順 9、 1の画像 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Screen Replacement: 手順 10、 1の画像 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Screen Replacement: 手順 11、 1の画像 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Screen Replacement: 手順 12、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 12、 2の画像 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Screen Replacement: 手順 13、 1の画像 1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Screen Replacement: 手順 14、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 14、 2の画像 2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Screen Replacement: 手順 15、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 15、 2の画像 2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Screen Replacement: 手順 16、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 16、 2の画像 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Screen Replacement, Screen: 手順 17、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement, Screen: 手順 17、 2の画像 2
    • There is a metal component connecting the screen to the casing underneath each hinge.
    • Remove three 5.6 mm screws with a Phillips 1 screwdriver on each side.
  18. HP Pavilion 17-f004dx Screen Replacement: 手順 18、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 18、 2の画像 2
    • Lift the black retaining flap to remove the black cable connecting the screen to the motherboard.
  19. HP Pavilion 17-f004dx Screen Replacement: 手順 19、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 19、 2の画像 2
    • Gently remove the black ribbon that was connected to the black flap.
  20. HP Pavilion 17-f004dx Screen Replacement: 手順 20、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 20、 2の画像 2
    • Locate the thin black wire that trails from the screen and remove it from the motherboard.
  21. HP Pavilion 17-f004dx Screen Replacement: 手順 21、 1の画像 1
    • Remove two small rubber covers on the bottom right and left edges of the screen enclosure using a metal spudger to expose two screws.
  22. HP Pavilion 17-f004dx Screen Replacement: 手順 22、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 22、 2の画像 2
    • Remove one 5.6mm screw with a Phillips 1 screwdriver from each side of the bottom screen.
  23. HP Pavilion 17-f004dx Screen Replacement: 手順 23、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 23、 2の画像 2
    • Use a metal spudger to remove the plastic casing from the perimeter of the screen.
  24. HP Pavilion 17-f004dx Screen Replacement: 手順 24、 3の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 24、 3の画像 2 HP Pavilion 17-f004dx Screen Replacement: 手順 24、 3の画像 3
    • Be careful not to damage the wires.
    • Use a metal spudger to partially remove the screen from the plastic case.
  25. HP Pavilion 17-f004dx Screen Replacement: 手順 25、 2の画像 1 HP Pavilion 17-f004dx Screen Replacement: 手順 25、 2の画像 2
    • Do not touch the circuit board directly.
    • Flip the screen over and remove the tape that holds down the ribbon.
  26. HP Pavilion 17-f004dx Screen Replacement: 手順 26、 1の画像 1
    • Pull the ribbon away from the screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Chi Huynh
メンバー登録日: 09/21/16
675 ポイント
2のガイドは作成済み
チーム
UC Davis, Team 1-4, Oliver Fall 2016 UC Davis, Team 1-4, Oliver Fall 2016人のメンバー
UCD-OLIVER-F16S1G4
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 22
今までの合計 2,519
