メインコンテンツにスキップ
HP Pavilion 17-e146us Motherboard Replacement
必要な工具と部品
  1. HP Pavilion 17-e146us Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Turn the device over.
  2. HP Pavilion 17-e146us Motherboard Replacement: 手順 2、 2の画像 1 HP Pavilion 17-e146us Motherboard Replacement: 手順 2、 2の画像 2
    • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
    • The battery release button is located above the the battery.
  3. HP Pavilion 17-e146us Motherboard Replacement: 手順 3、 1の画像 1
    • The battery will unlock from the computer.
    • Remove the unlocked battery from the computer.
  4. HP Pavilion 17-e146us Motherboard Replacement, Keyboard: 手順 4、 3の画像 1 HP Pavilion 17-e146us Motherboard Replacement, Keyboard: 手順 4、 3の画像 2 HP Pavilion 17-e146us Motherboard Replacement, Keyboard: 手順 4、 3の画像 3
    • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
  5. HP Pavilion 17-e146us Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the HP protect smart ventilation case.
    • The smart ventilation is a part of the back cover of the device
  6. HP Pavilion 17-e146us Motherboard Replacement: 手順 6、 1の画像 1
    • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
    • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
  7. HP Pavilion 17-e146us Motherboard Replacement: 手順 7、 2の画像 1 HP Pavilion 17-e146us Motherboard Replacement: 手順 7、 2の画像 2
    • Pull and remove the disk drive.
    • The disk drive is located on the left side of the device when it is turned over.
    • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
  8. HP Pavilion 17-e146us Motherboard Replacement: 手順 8、 1の画像 1
    • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • The release port releases the keyboard.
  9. HP Pavilion 17-e146us Motherboard Replacement: 手順 9、 1の画像 1
    • Flip device over so that the cover is facing towards you
  10. HP Pavilion 17-e146us Motherboard Replacement: 手順 10、 3の画像 1 HP Pavilion 17-e146us Motherboard Replacement: 手順 10、 3の画像 2 HP Pavilion 17-e146us Motherboard Replacement: 手順 10、 3の画像 3
    • Open device. The keyboard should be separate from the inside panel.
    • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
    • Detach the keyboard's cable connector from the motherboard.
  11. HP Pavilion 17-e146us Motherboard Replacement, Motherboard: 手順 11、 1の画像 1
    • Remove three 6.5 mm Phillips screws located underneath the keyboard using a Phillips #0 screwdriver.
  12. HP Pavilion 17-e146us Motherboard Replacement: 手順 12、 1の画像 1
    • Place wedge tool in-between the front panel and the cover underneath the keyboard
    • Use wedge tool to pop the two covers apart.
    • This may require some force.
  13. HP Pavilion 17-e146us Motherboard Replacement: 手順 13、 2の画像 1 HP Pavilion 17-e146us Motherboard Replacement: 手順 13、 2の画像 2
    • Remove the motherboard using your hands
    • The motherboard is large green portion located inside the device
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Emma Neumann
メンバー登録日: 09/04/19
629 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S2-G7, Bedsole Fall 2019 University of Alabama, Team S2-G7, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S2G7
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 877
