はじめに
If you need to remove or replace the hard drive in your HP Pavilion 15-p214dx, this guide will show you how. Although a Philips #0 screwdriver, a plastic opening tool, and possibly a flathead screwdriver are needed to open up the computer, removing the hard drive itself is as simple as disconnecting a couple cables and pulling the component out of the computer.
必要な工具と部品
Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
Remove this screw using a Philips #0 screwdriver.
Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
Open the clip holding the USB connector cable in place, then slide the cable out of the clip.
Open the clip that holds the hard drive cable in place, then remove the cable from that port.
Tilt the hard drive so that it slopes down to the right, then pull it out of the computer.
ある他の人がこのガイドを完成しました。
