はじめに
If your RAM no longer works, you’ve come to the right place. This guide will walk you through how to replace your notebook’s RAM. Common signs that you need to replace your RAM card are if after turning on your computer its performance begins to slow down or your computer randomly crashes or restarts when running multiple apps. Before getting started, be sure to completely disconnect power from the device.
必要な工具と部品
Flip the laptop over so the bottom is facing up.
Place your finger on the top left-hand slide button with the lock symbol.
Slide the button to the right so that an unlocked symbol is visible.
Remove screw covers from the hinge covers on the upper left and right side.
Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
Remove hinge covers by pulling up and out on the top of the cover.
Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the three ribbon cables on the bottom right corner of the motherboard.
Grab each ribbon cable and gently pull away from the socket.
Move the ribbon cables away from the motherboard.
