メインコンテンツにスキップ
HP Pavilion 15-p046nr RAM Replacement
必要な工具と部品
  1. HP Pavilion 15-p046nr RAM Replacement, Battery: 手順 1、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement, Battery: 手順 1、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement, Battery: 手順 1、 3の画像 3
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr RAM Replacement: 手順 2、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 2、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement: 手順 2、 3の画像 3
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr RAM Replacement, Integrated Keyboard: 手順 3、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement, Integrated Keyboard: 手順 3、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement, Integrated Keyboard: 手順 3、 3の画像 3
    • Remove screw covers from the hinge covers on the upper left and right side.
    • Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
    • Remove hinge covers by pulling up and out on the top of the cover.
  4. HP Pavilion 15-p046nr RAM Replacement: 手順 4、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 4、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement: 手順 4、 3の画像 3
    • Remove thirteen 7 mm screws from the back panel using the Phillips #00 screwdriver.
    • Remove three 5 mm screws from the back panel using the Phillips #00 screwdriver.
    • Grab the disk drive on the left side and pull the disk drive out completely.
    • Flip the laptop over and open the display.
  5. HP Pavilion 15-p046nr RAM Replacement: 手順 5、 2の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 5、 2の画像 2
    • Run the plastic opening tool along the entire edge of the keyboard to separate the keyboard from the base of the laptop.
    • Gently lift the keyboard tray up.
    • Use care to lift the keyboard off of the device. The keyboard is still attached by ribbon cables.
  6. HP Pavilion 15-p046nr RAM Replacement: 手順 6、 2の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 6、 2の画像 2
    • Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the two ribbon cables connecting the keyboard to the device.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the ribbon cable and gently pull away from the socket.
    • To reinstall, insert the ribbon cable into the connector and close the flap on the black line.
  7. HP Pavilion 15-p046nr RAM Replacement: 手順 7、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 7、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement: 手順 7、 3の画像 3
    • Lift the keyboard up and away from the device.
    • Removing the keyboard exposes the motherboard and its sensitive components. Ensure no tools or items are set on the motherboard or it could cause damage.
  8. HP Pavilion 15-p046nr RAM Replacement, Motherboard: 手順 8、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement, Motherboard: 手順 8、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement, Motherboard: 手順 8、 3の画像 3
    • Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the three ribbon cables on the bottom right corner of the motherboard.
    • Grab each ribbon cable and gently pull away from the socket.
    • Move the ribbon cables away from the motherboard.
  9. HP Pavilion 15-p046nr RAM Replacement: 手順 9、 2の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 9、 2の画像 2
    • To disconnect the speakers, carefully pull on the cables that connect to the motherboard from the speaker system.
    • Be careful not to yank or jerk the cables because they can be easily broken.
    • Move the speaker cables away from the motherboard.
  10. HP Pavilion 15-p046nr RAM Replacement: 手順 10、 2の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 10、 2の画像 2
    • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the grey locking flap of the webcam ribbon cable.
    • Grab the ribbon cable cable and gently pull away from the socket.
  11. HP Pavilion 15-p046nr RAM Replacement: 手順 11、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 11、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement: 手順 11、 3の画像 3
    • Unscrew one 6 mm screw on the wireless card with the Phillips #00 screwdriver.
    • The wireless card will angle upwards when the screw is removed.
    • Gently pull the wireless card away from the motherboard with the same angle that it rests.
  12. HP Pavilion 15-p046nr RAM Replacement: 手順 12、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 12、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement: 手順 12、 3の画像 3
    • In the upper left corner of the motherboard, unscrew one captive screw from the charger port cover with the Phillips #00 screwdriver.
    • "Captive screws" are those which will cannot be removed, but will instead remain within their screw hole after being disengaged.
    • Remove the charger port cover.
    • Carefully pull upwards on the charger port to disconnect it.
    • The charger port will stay attached to the device.
  13. HP Pavilion 15-p046nr RAM Replacement: 手順 13、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 13、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement: 手順 13、 3の画像 3
    • Remove the four 6 mm screws from the motherboard using the Phillips #00 screwdriver.
    • Gently lift the motherboard directly up from the holding slots and remove the motherboard from the device.
    • Be careful not to put too much pressure on the motherboard while lifting it up, as there are many fragile circuits and chips on it.
    • Remove the motherboard from the device once it's clear of all cables and slots.
    • Be sure that all cables are clear before reinstalling the motherboard as to not catch any cables beneath.
  14. HP Pavilion 15-p046nr RAM Replacement, RAM: 手順 14、 3の画像 1 HP Pavilion 15-p046nr RAM Replacement, RAM: 手順 14、 3の画像 2 HP Pavilion 15-p046nr RAM Replacement, RAM: 手順 14、 3の画像 3
    • Flip the motherboard over to reveal the RAM card in the bottom right corner.
    • Gently pull both silver locking tabs simultaneously away from eachother.
    • The RAM card will pop up once both tabs are pulled
    • When installing the RAM, there will be a popping noise when it clicks into place.
  15. HP Pavilion 15-p046nr RAM Replacement: 手順 15、 2の画像 1 HP Pavilion 15-p046nr RAM Replacement: 手順 15、 2の画像 2
    • Grab the RAM card and gently pull it out from the motherboard maintaining the angle at which it rests.
    • Remove the RAM card from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Betsabe Hernandez
メンバー登録日: 09/18/19
835 ポイント
8のガイドは作成済み
チーム
コメント 1 件
Good job. May I suggest that you can even add gifs to your guides.
Henry Opia - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 664
