はじめに
If your screen no longer works on your HP Pavilion 15-p046nr, you’ve come to the right place. This guide will walk you through how to replace your notebook’s screen. You may need to replace your screen if it has been damaged in some way (water, crushed, white spots, cracking). Further signs you may need to change your display is if your display refuses to turn on for no apparent reason. You will need a magnetic project mat, Phillips 00 screwdriver, and plastic opening tool for this replacement. Be sure to to completely disconnect power from your device before working on your notebook.
必要な工具と部品
Flip the laptop over so the bottom is facing up.
Place your finger on the top left-hand slide button with the lock symbol.
Slide the button to the right so that an unlocked symbol is visible.
Remove screw covers from the hinge covers on the upper left and right side.
Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
Remove hinge covers by pulling up and out on the top of the cover.
Use the tip of the blue plastic opening tool to gently flip-up the black locking flap of the cable connecting the motherboard to the display.
Grab the cable and gently pull away from the socket.
Remove the two 2 mm screws from around the display using the Phillips #00 screwdriver.
Remove two 1.5 mm screws from around the display using the Phillips #00 screwdriver.
Carefully peel off the tape at the bottom of the screen to separate the green chip from the screen.
Remove the screen from the display.
