はじめに
If your battery no longer works on your HP Pavilion 15-p046nr, you’ve come to the right place. This guide will walk you through how to replace your notebook’s battery. You may need to change your battery if your computer cannot operate without being connected to a wall outlet or if your battery is not charging to full capacity. You do not need any special tools. Before you get started, be sure to completely disconnect power from your device.
Flip the laptop over so the bottom is facing up.
Place your finger on the top left-hand slide button with the lock symbol.
Slide the button to the right so that an unlocked symbol is visible.
ある他の人がこのガイドを完成しました。
