メインコンテンツにスキップ
HP Pavilion 15-d035dx USB Port Replacement
必要な工具と部品
  1. HP Pavilion 15-d035dx USB Port Replacement, Battery: 手順 1、 3の画像 1 HP Pavilion 15-d035dx USB Port Replacement, Battery: 手順 1、 3の画像 2 HP Pavilion 15-d035dx USB Port Replacement, Battery: 手順 1、 3の画像 3
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx USB Port Replacement, Front Panel: 手順 2、 1の画像 1
    • Begin by laying the laptop on its backside with the bottom of the laptop facing you.
  3. HP Pavilion 15-d035dx USB Port Replacement: 手順 3、 2の画像 1 HP Pavilion 15-d035dx USB Port Replacement: 手順 3、 2の画像 2
    • There will be 11, 2.5x3.0mm Philips head screws that you will need to locate.
    • Continue by unscrewing all of them using a 0 Phillips screwdriver.
  4. HP Pavilion 15-d035dx USB Port Replacement: 手順 4、 3の画像 1 HP Pavilion 15-d035dx USB Port Replacement: 手順 4、 3の画像 2 HP Pavilion 15-d035dx USB Port Replacement: 手順 4、 3の画像 3
    • Take off the back panel by removing the 4.0x4.7mm Philips head screw.
    • Then using the opening tool, work around the edges to pull off the back panel.
    • It will take some force to get the back panel off.
  5. HP Pavilion 15-d035dx USB Port Replacement: 手順 5、 1の画像 1
    • Now flip the computer right side up and open up the laptop.
    • You should be facing the screen and keyboard.
  6. HP Pavilion 15-d035dx USB Port Replacement: 手順 6、 1の画像 1
    • Now using the opening tool remove the front panel from the back panel.
    • It should start to pop off, you will have to do this step around the entire computer.
    • It will give some resistance so take your time to ensure that nothing breaks.
  7. HP Pavilion 15-d035dx USB Port Replacement: 手順 7、 1の画像 1
    • Once you have popped off the panel it should simply be able to lift off of the laptop.
    • Keep in mind that the keyboard is still connected to the motherboard. Simply lay the keyboard on top of the screen while you are completing future guides.
    • You can replace the front panel now.
  8. HP Pavilion 15-d035dx USB Port Replacement, USB Port: 手順 8、 1の画像 1
    • The USB Hub will be on the right side of the HP Pavilion Laptop.
  9. HP Pavilion 15-d035dx USB Port Replacement: 手順 9、 1の画像 1
    • There will be two screws (4.0x4.7mm) that need to be removed so lift the Hub away from the computer.
  10. HP Pavilion 15-d035dx USB Port Replacement: 手順 10、 1の画像 1
    • Next disconnect the flat cable by pulling the cable straight out of the connector from the USB Hub.
終わりに
作成者
2人の作成者と共同で作成されました。
Stone Morris
メンバー登録日: 09/25/17
101 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G2, Thompson Fall 2017 University of North Texas, Team S1-G2, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 1,228
