メインコンテンツにスキップ
HP Pavilion 15-d035dx RAM Replacement
必要な工具と部品
  1. HP Pavilion 15-d035dx RAM Replacement, Battery: 手順 1、 3の画像 1 HP Pavilion 15-d035dx RAM Replacement, Battery: 手順 1、 3の画像 2 HP Pavilion 15-d035dx RAM Replacement, Battery: 手順 1、 3の画像 3
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx RAM Replacement, Back Panel: 手順 2、 1の画像 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  3. HP Pavilion 15-d035dx RAM Replacement: 手順 3、 3の画像 1 HP Pavilion 15-d035dx RAM Replacement: 手順 3、 3の画像 2 HP Pavilion 15-d035dx RAM Replacement: 手順 3、 3の画像 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  4. HP Pavilion 15-d035dx RAM Replacement: 手順 4、 1の画像 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
  5. HP Pavilion 15-d035dx RAM Replacement, RAM: 手順 5、 1の画像 1
    • Locate the RAM, it is about a 2 inch by 1 inch rectangle that is blue in color.
  6. HP Pavilion 15-d035dx RAM Replacement: 手順 6、 1の画像 1
    • Press down on the small silver latches on either side of the RAM, the RAM should pop up. While doing this you will hear a faint click.
  7. HP Pavilion 15-d035dx RAM Replacement: 手順 7、 1の画像 1
    • Finally remove the RAM by pulling it away from the black connection panel.
    • Once the RAM is removed you can put in the replacement RAM.
終わりに
作成者
2人の作成者と共同で作成されました。
Meredith Shaffer
メンバー登録日: 09/25/17
222 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S1-G2, Thompson Fall 2017 University of North Texas, Team S1-G2, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 416
