メインコンテンツにスキップ
HP Pavilion 15-d035dx Disk Drive Replacement
必要な工具と部品
  1. HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 手順 1、 3の画像 1 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 手順 1、 3の画像 2 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 手順 1、 3の画像 3
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx Disk Drive Replacement, Back Panel: 手順 2、 1の画像 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  3. HP Pavilion 15-d035dx Disk Drive Replacement: 手順 3、 3の画像 1 HP Pavilion 15-d035dx Disk Drive Replacement: 手順 3、 3の画像 2 HP Pavilion 15-d035dx Disk Drive Replacement: 手順 3、 3の画像 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  4. HP Pavilion 15-d035dx Disk Drive Replacement: 手順 4、 1の画像 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
  5. HP Pavilion 15-d035dx Disk Drive Replacement, Disk Drive: 手順 5、 1の画像 1
    • Once you have removed the panel there is one screw (2.5x6mm) that will need to be unscrewed.
  6. HP Pavilion 15-d035dx Disk Drive Replacement: 手順 6、 2の画像 1 HP Pavilion 15-d035dx Disk Drive Replacement: 手順 6、 2の画像 2
    • After unscrewing the back screw for the disc drive another 14 screws (2.5x6.0mm) will need to be removed.
  7. HP Pavilion 15-d035dx Disk Drive Replacement: 手順 7、 1の画像 1
    • Now flip the computer back to right side up.
    • Using the plastic opening tool from iFixit to pry open the top half of laptop case. Take off the top half.
  8. HP Pavilion 15-d035dx Disk Drive Replacement: 手順 8、 2の画像 1 HP Pavilion 15-d035dx Disk Drive Replacement: 手順 8、 2の画像 2
    • Now seeing the inside of the laptop. Unscrew one more screw (2.0x3.0mm).
  9. HP Pavilion 15-d035dx Disk Drive Replacement: 手順 9、 3の画像 1 HP Pavilion 15-d035dx Disk Drive Replacement: 手順 9、 3の画像 2 HP Pavilion 15-d035dx Disk Drive Replacement: 手順 9、 3の画像 3
    • Now you should be able slide the disk drive out to the side.
    • Do not pull up on the disk drive. This could damage the plug ins and/or the case that help holds it all together.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
John Atkins
メンバー登録日: 09/25/17
273 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S1-G2, Thompson Fall 2017 University of North Texas, Team S1-G2, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 1,092
