メインコンテンツにスキップ
HP Pavilion 15-d017cl Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion 15-d017cl Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 HP Pavilion 15-d017cl Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Flip the laptop onto its back in order to have access to the back "L" shaped panel.
    • Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
  2. HP Pavilion 15-d017cl Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion 15-d017cl Hard Drive Replacement: 手順 2、 2の画像 2
    • To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
    • This may require a good amount of strength to loosen the panel. As the opening tool is moving around the panel, clicking noises will be heard.
  3. HP Pavilion 15-d017cl Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove the fifteen (15) 5 mm screws using the Phillips #1 Screwdriver.
  4. HP Pavilion 15-d017cl Hard Drive Replacement: 手順 4、 3の画像 1 HP Pavilion 15-d017cl Hard Drive Replacement: 手順 4、 3の画像 2 HP Pavilion 15-d017cl Hard Drive Replacement: 手順 4、 3の画像 3
    • Flip the computer over so the screen and keyboard are showing.
    • Using the opener tools, pry around the edges of the computer in between the keyboard and the base.
    • Apply enough pressure to unlatch the keyboard but be cautious of the parts under it.
    • Flip the keyboard up toward the screen to access the motherboard.
  5. HP Pavilion 15-d017cl Hard Drive Replacement: 手順 5、 3の画像 1 HP Pavilion 15-d017cl Hard Drive Replacement: 手順 5、 3の画像 2 HP Pavilion 15-d017cl Hard Drive Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Using the Spudger, press into the silver latch and lift it up.
    • Using the Tweezers, pull the Ribbon Cable out of the silver latch.
  6. HP Pavilion 15-d017cl Hard Drive Replacement: 手順 6、 3の画像 1 HP Pavilion 15-d017cl Hard Drive Replacement: 手順 6、 3の画像 2 HP Pavilion 15-d017cl Hard Drive Replacement: 手順 6、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the three screws located around the hard drive.
    • When finished unscrewing, pull the hard drive out.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Noah Pecor
メンバー登録日: 09/24/19
646 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 9
今までの合計 1,338
