メインコンテンツにスキップ
HP Pavilion 15-cd040wm Back Cover Disassembly
必要な工具と部品
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 1、 2の画像 1 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 1、 2の画像 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 2、 2の画像 1 HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 2、 2の画像 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 3、 3の画像 1 HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 3、 3の画像 2 HP Pavilion 15-cd040wm Back Cover Disassembly: 手順 3、 3の画像 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Joe Krawczyk
メンバー登録日: 11/01/19
397 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G1
4 メンバー
7のガイドは作成済み
3 件のコメント
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - 返信
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - 返信
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 33
過去 30 日: 137
今までの合計 8,193
