はじめに
Make sure the power cord is not plugged in and that the device is powered completely off before you begin. Before making any hardware changes to this laptop, make sure the battery is completely removed. This will make repair safer for both you and your laptop.
必要な工具と部品
Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
7 の人々がこのガイドを完成させました。
2 件のコメント
If you plan to replace it yeah, what do you even plan to replace? battery, no, harddrive, no, and im not sure about the other stuff.
